mdwerner6942 Posted November 20, 2015 Report Posted November 20, 2015 Single 15 inch 3.5 Cu.ft. Ported L-Vented 3/4MDF Subwoofer Enclosure Box (Said he used bass box pro.) Item Description Width: 25" Depth: 21 1/2" Height: 16 1/2" Gross Airspace: 4.12 Cu.Ft. Net Airspace: 3.5 Cu.Ft. Port Dimensions: 15" X 2 1/2" X 28 3/4" Port Volume: .62 Cu.Ft. Tuned @ 29hz One spring loaded speaker terminal.Constructed of industrial U.S. grade 3/4" MDF.Covered with industrial grade trunk liner carpet.Quality glued and sealed with hotmelt glue.Now I get a little less box myself but solid box. Ported box we recommend using 2.8-4 cubic feet @ 28-33Hz. Again use 12-16 square inches of vent area per one cubic foot of volume. Not sure how good my software is on this and just seeing if this might be a fit, Sq-Q1-2200 amp. Holding on this hoping black Friday offers show up soon Facebook thought it started guess not, not see any coupons yet but will see. I decided to go a different woofer and see if this box will work. Q seem a nice option if this will work, change from BL 18, but it just got to much to lift after accident. AB and SQ did not see specs, so Fi been good for me in past thought why not, Nick Scott always seem to do great thinks guess that is why others use their parts and or expertise. Displacement of sub is not used yet just box it self.
Subwoofer Stokes Posted November 20, 2015 Report Posted November 20, 2015 I run the Q 18 and its good bro <p>Black 1997 Chevy C1500 Ext. Cab5.7L 350 VortecDual 22" Glasspack ExhaustRacing Chip/Programmer.373 Gears W/ Shift KitCold Air IntakePioneer Deh80-PrsSubwoofers-Fi Q motor, 18 6 spoke basket, SPL Audio recone
mdwerner6942 Posted November 20, 2015 Author Report Posted November 20, 2015 I run the Q 18 and its good bro Box- 24x22.25x20 Port 2.75x20.74x32 this would of been for 15" tune close to 33 Hz I believe
mdwerner6942 Posted January 2, 2016 Author Report Posted January 2, 2016 I run the Q 18 and its good bro thanks, got one but going sealed just curious, now need to decide on amp,
