Dispensa Posted December 5, 2015 Author Report Share Posted December 5, 2015 Sounds like a possible intermittent connection (ground maybe). Pull head unit out and check all the connections. Make sure they're properly soldered or seated. Although I wouldn't think just a simple lost signal would cause that much static... Try out all the suggestions above as well to see if you can pin it down to something specific. thanks for the suggestion. Been slammed with work when i get the free time i will update to see if anything was loose or etc. Wanted to make the post to see if anyone has had similar problems for answers. The static was very loud. not just a faint static like the louder the volume, the static went up. Link to comment Share on other sites More sharing options...
Dispensa Posted December 5, 2015 Author Report Share Posted December 5, 2015 My first guess is the antenna cable slipped out, but that's why I asked what source(s) have this problem. Antenna being AM/FM radio? if so i don't even have it hooked up. lol Link to comment Share on other sites More sharing options...
