2012 Toyota 4Runner SQ+ build
AA109079-7371-4F42-96DE-2CFC3B615F77_zps
Not to pick anything apart, but why did you use different sized wire to go from the block to the fuse blocks?
Otherwise it looks good.
I know for some people, we want rear fill to satisfy our other passengers, kids, etc. I know for me, I want ot be able to turn up the sound so they can hear it, but not be blasting me out of the front seat. A bit exaggerated but you get the idea.
Keep up the good work, I'm enjoying this one.
Nitpick away, I'm new to this.
The hexagon distribution block has two 1/0 holes, two 4 gauge holes, and two 8 gauge holes.
1 1/0 goes to battery at front of car.
1 1/0 goes to P1000.1 amp
So, now both 1/0's are used. The 4 gauge will provide power to a P900.4 and a P600.2, both at 4 ohms per channel and a JBL MS-8.
Well, if I may suggest something that would clean things up big time. Just a suggestion.
I would eliminate the hexagon fuse holder all together. The one on the bottom looks like it's your line in correct? If so, I would center that on the left side (the side it's on) and take the other two off of that side. I would put those two on the right side.
You said 1 1/0 from the battery and 1 1/0 to the p1000.1. Then you named 3 4ga (p900.4, P600.2, and the MS8. You have 4. Is one a dummy wire, so to speak? Is your 1/0 for your p1000.1 going to be fused? If you're going to use the same type of fuse holder, as the 4ga holders, that has the 3 way inputs, I would do that 1/0 fuse holder in the middle directly centered with the input fuse holder. Then put one 4ga holder on top, and one on bottom of it, with the 1/0 going in between them to tie them all together. Would be a much nicer, neater, cleaner in and out look to it.
Sorry like I said, just a suggestion, not by any means something you have to do.
Either way I think you're making good progress and doing good work.
Just to clarify on the fusing.
From top to bottom.
JBL MS-8
Miscellaneous including neons and temp controller. These will also have inline fuses.
P600.2
P900.4
The ANL fuse is for the P1000.1 amp.
Ah, you beat me to it. I was typing lol.
Ok then, on what I just said. I would still use that fuse for the input, and then use another fuse for the P1000.1. IF you used the same type of inline fuse, without the 3 way, you could unscrew the input side. It usually has a screw in from the bottom under the plastic mount. Unscrew it just to loosen in, and then spin it so it faces the 4ga holders. Then you can put it on the top or bottom, whichever.
Have the 1/0 from the battery into the fuse holder, out into the center 4ga fuse holder. Then a 1/0 from there to the second 4ga fuse holder, and to the 1/0 fuse holder.
Or, another way to do it, if you don't want to add a second single fuse holder for the input, center all three fuse holders, and do the same as I just described, except the 1/0 from the battery just goes into the 4ga fuse holder input instead.
Make sense?
From top to bottom.
JBL MS-8
P600.2
P900.4
Make sense?
Why would you add a fuse from the battery? It's going to have a fuse at the battery.
As for changing it, to be honest, I kind of like it the way it is. I may change my mind later on.
I managed to get everything hooked up today and I finally got to hear it. It's going to take a good bit of tuning but I'm just happy it's playing.
First off, the speaker connections. The red and clear wires will be replaced with blue and black wires once they show up.
7D93CE71-BB15-4130-B456-801C11A91AE7_zps
A comparison between the Alpine Type R 6's that I removed and the PPI's that I replaced them with.
C342A3AF-1C17-4AA5-9258-9EA4C0951673_zps
Midrange and Tweeters hooked up and installed.
992B700D-1313-443F-905A-05A2DC32C6B8_zps
B9596F84-803E-44FB-AD20-F793DC52353E_zps
AF9AB3F7-9187-4D65-9553-1195A5BC89E7_zps
Door speakers hooked up and installed. More sound deadening and MDF speaker rings will be among the first upgrades.
B7F5592A-DD72-49D7-B3E1-A1219430A4E7_zps
3D053F1C-6AD0-4798-ABB7-2723AA35C04F_zps
I'm not sure if this will help any but it certainly won't hurt anything.
BC822590-B484-49F9-838D-FCB27E116133_zps
All back together.
6B8861DA-CA1B-42AF-9AEA-456582D825D0_zps
How's this for an ugly tune?
88CADCA9-BB71-41B4-817C-EC8992703F25_zps
All back together.
I like that wiring. Looks good.
Getting there. Home stretch!!
What are your initial thoughts of it. You said it's going to take a bit of tuning. Just firing it up, how does it sound?
Thanks. To me it sounds amazing but I haven't heard a high end car stereo for around fifteen years. I'm sure I'll be changing my mind after my first competition. :)
Oh yeah, for sure!!
Competitions are the only way to really hone in a system in my opinion. Obviously you can get help from others, and equipment etc. But if you can't hear perfection or high quality for yourself, you'll just be shooting in the dark.
I'd highly advise going to a few shows after you tune a little. That's what I did when I had my civic, before I came to the "bass life side of things". LOL.
Good luck. Keep plugging away!
