CoolXoc Posted April 19, 2008 Report Posted April 19, 2008 i need a slot ported box design, tuned to 30hz. now i'm running with an passive radiator box ,but its old and damaged.. my sub: GROUND ZERO Uranium 12" 1000wrms Schwingspule mm/ inch 75 / 3” Impedanz Ohm 2 x 3,6 Fs Hz 28,9 Qms 3,14 Qes 0,49 Qts 0,42 Vas Liter / cu.ft. 35,4 / 1.25 Xmax mm/ inch 25 / 1.0” SPL dB/m 89 Power W/RMS 1000 BL Tesla Meter 26,0 Lochausschnitt / Mounting hole 281 / 11.1” Einbautiefe / Mounting depth 165 / 6.55” the box is to an hatchback one of the sides cannot be more than 12" or 13" of length, because my car's trunk is to tight ( 30~35cm, or 12~13" height) can someone help me? bassbox pro dont help me too much doing slot ported box's.. thanks
sully Posted April 23, 2008 Report Posted April 23, 2008 Either that sub does not like ported boxes or Bass Box Pro doesn't like it at all. I played with it for a couple minutes and came up with: H 12 W 29 d 18.5 Port: 2"x10.5"x23" (shortest port that looked decent on the graph) Looks like it will sound ok without being too peaky. Doesn't have as good a bump on the graph as I like to see but it should play music very well. Also It is tuned to 32.5 not 30, sorry didn't remember to change that value until I was done. 30 is a little low for a single 12 anyway, IMO wouldn't get the benefit of using a smaller woofer for the mid bass punch. If you want 30hz tuned box you should try a 15 or 18" woofer. 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
CoolXoc Posted April 25, 2008 Author Report Posted April 25, 2008 Either that sub does not like ported boxes or Bass Box Pro doesn't like it at all. I played with it for a couple minutes and came up with:H 12 W 29 d 18.5 Port: 2"x10.5"x23" (shortest port that looked decent on the graph) Looks like it will sound ok without being too peaky. Doesn't have as good a bump on the graph as I like to see but it should play music very well. Also It is tuned to 32.5 not 30, sorry didn't remember to change that value until I was done. 30 is a little low for a single 12 anyway, IMO wouldn't get the benefit of using a smaller woofer for the mid bass punch. If you want 30hz tuned box you should try a 15 or 18" woofer. thanks for the design! this sub is a sq sub... this is a 784.5 US$ sub..so it have to be something good but even so it can beat very well for spl( for me..) is a spql sub
sully Posted April 25, 2008 Report Posted April 25, 2008 let me know how it sounds if you decide to build that box. 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
CoolXoc Posted May 1, 2008 Author Report Posted May 1, 2008 let me know how it sounds if you decide to build that box. hi! well i made the box..with other dimensions ( my car's trunk is to tight) just a teaser lol almost finished
