Will this box work or will it sound bad?
What subs? What amp? How much port area?
Builds:
Boy, you are rocking the old-school hardware.
So, I can't really give you an informed opinion because I haven't worked with those subs before and Kicker doesn't publish hardly any specs on them. They will probably work in 2.5 cubes each, but its below Kickers recommendation of 3-6 cu ft each. I've played with the 12" version of those subs and they liked a big box, so performance is probably going to be less than ideal with what you want to do.
Also, I'd avoid that RE audio box calculator, it doesn't account for sub displacement and has other things that make it less than ideal.
Builds:
Using the parameters from here winisd shows that it wants a big box for it to hit the lower freq's. Also on that page it says in the box recommendations that it wants 6 cubes + port for "deep bass/SPL"
If I were you I'd seal off 2 of the holes for the woofers and run 2 so that you get 5 cubes each.
Here's a a graph of the predicted response:
Blue line is 2 l5 15's in a 10 cube box tuned to 33hz
Green line is 4 l5 15's in a 10 cube box tuned to 33hz
  • Who's Online   0 Members, 0 Anonymous, 944 Guests (See full list)
