NoName Posted March 23, 2016 Report Posted March 23, 2016 Time has come to change my sealed OEM spec. box and change it with a ported one.Subwoofer: JL Audio 10w3v2-4Amp: DLS D1000Car type: WagonCurrent box: Sub spec:Box I am aiming to build: (picture just for reference, I know this one is 12". I want one which would go trough the length of the trunk.)1.2 cubic feet33hz (maybe lower??)Something like this, too bad its not in my continent..http://www.lifeafterbass.com/labsl1ftpomd10.htmlI have never designed a box myself, I have the tools I have the boards and I have the skills. Just no design knowledge. Trunk space I have is 35" (88cm) length, 15" (38cm) height and depth is not important.Could someone help me draw, design this box? THANK YOU IN ADVANCE
DonkeysBreath Posted March 23, 2016 Report Posted March 23, 2016 What orientation do you wish for the sub face and port to be in? If you what an enclosure similar to the in this explorer(my gut tells me its an 2002 or 2003 but this is getting off topic) is your length spec provided from wheel well to wheel well then or from seats to back gate? With an internal displacement of 1.2cu (not counting woffer/port displacement) you can pull off a box build like this (spanning the full 35 inches) with just enuf depth left to mount this driver with no troubles. And one final thing dose JL have a recommended/optimal ported enclosure, because that would be best for a new builder like your self.
NoName Posted March 23, 2016 Author Report Posted March 23, 2016 Thanks for the reply. Sub on the left side, port on the right side (opposite then the picture) car is not explorer, but Toyota avensis/caldina.Measurements are like this:For the OEM spec box. I had a chance to listen to it. Didn't like it, its very small and tuned to 37hz. Read quite a few forum posts suggesting a bigger, lower tuned box. I think LAB slapbox would fit my need, but I can't buy it locally, so why not to build it.
Jhunt94 Posted March 23, 2016 Report Posted March 23, 2016 Not 100% sure, but you might could email LAB and see if they would sell you a cut sheet for that box. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
NoName Posted March 23, 2016 Author Report Posted March 23, 2016 That's an idea, but if I'm building that box, it would be awesome to make it to fit my car. LAB has all dimensions provided except port length.
Jhunt94 Posted March 23, 2016 Report Posted March 23, 2016 That's why I suggested emailing them about the cut sheet. (IF) they will send you one it will specify all of the dimensions, including the port length. Some other people may chime in, and offer their box design services for free. I'm not as skilled with box design software compared to some of the other members on here. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
NoName Posted March 23, 2016 Author Report Posted March 23, 2016 Well let's hope for a miracle and someone that will help me.
Esgedi Posted March 23, 2016 Report Posted March 23, 2016 In the case that they aren't willing to provide it, box design is simple. Download sketchup, and have a go at it. There are only 2 things you need to know to really build a good box. 1, the higher the panel resonance the better. Bracing increases resonance.2, air flows like water. Those two fundementals are all you really need to get started. The only way to get good at is trial and error. Download some programs like hornresp, bassbox, and winisd. Play around with them, hop on the googler, and just learn as much as you can. All of us started with nothing, and trust me, when it comes to box design the dunning kruger effect is in full play.Those who claim to be experts actually know very little. They know so little in fact, that they don't realize how little they know. There are very few set rules when it comes to box design. You need to learn for yourself how each aspect affects end result. Start reading, never over estimate your abilities. Don't trust a shop but you personally just smoked two decks, makes sense. 03' Trailblazer LTDayton Designer 6.5"s & Silkie tweetersDayton Audio Ultimax 18"Pioneer 9601 & 8604XS Power D34002 runs 1/0Singer 250
Jhunt94 Posted March 23, 2016 Report Posted March 23, 2016 Also you can download WinISD, input the dimensions of that slap box and then play around with the port size to get the tuning that you want. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
NoName Posted March 23, 2016 Author Report Posted March 23, 2016 Thanks for the program suggestions. Will post sketches later today. Will want your opinions.
