Andrew Storlie Posted March 25, 2016 Report Posted March 25, 2016 basicly im hand building a bluetooth speaker and im trying to figure out some math dealing with relative "loudness" the amp im working with i assume is about 8w-10 per channel left and right. taken from a cheap bluetooth speaker trying to figure out using math which of 2 speakers would get louder SPEAKER 1 specs 20rms rated 85.7db 2.83v/1m 80-15k hz 3.5" size SPEAKER 2 30rms rated 87.5db 2.83v/1m 80-20k hz 4" size but has a phase plug in center given the same wattage i would assume the 1st speaker would get louder given its a higher % of the rms wattage but then the 2nd speaker has a little bit higher efficiency.... both have same 4mm xmax's and 4ohm loads
ALPINE408 Posted March 25, 2016 Report Posted March 25, 2016 spec's only tell half the story Install tells the other half.............. Have you ever had your woofers blown?
