Dodge charger box
dsw422
Hey guys.. I'm getting ready to build a box for an 07 charger.. the subwoofer is a 15"re xxx custom made with Ultra soft parts.. around 4k rms..
Question is, a proper size box won't fit thru trunk.. so it will have to be a build in trunk box or at least 2 pieces.. what do yall recommend??
Also will be going to make beauty panels to hide batteries (which sit in the pockets behind tail lights). Will these beauty panels reduce the sound waves going to the cabin?
Here's the current setup.. Box is way to small..
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
You need to post your max space avalible... What is your goal ? Do you like lows or SQ ? Box size and porting is different for each.
I have the design of the box.. my question was would would a built in trunk or 2 piece box be easier?? Also, would beauty panels limit sound transfer to cab..
1994 Ford Bronco
Sony door speakers
Sorry man i wish i could help you further but i dont know how i can help you much... Usually you build a box depending on avalible space. Some people build a box out of cardboard then test fit to see if it works. You could cut some holes in your rear deck lid to allow air flow into your cabin... Trial and error brother.
Can you take out the back seats to allow access to the trunk ? If so you can prolly get it through there. How big is the box ? 4 cubes net ?
Cutting the deck is not an option. And there is not enough room to even consider sliding the box where the seats are.. this Trunk is terrible for a 15" sub. Ugh
1994 Ford Bronco
Sony door speakers
  • Who's Online   0 Members, 0 Anonymous, 3117 Guests (See full list)
