Need help with sa8-v2 box design
Noah Lee
Do you have any space to make the box bigger?
Builds:
That helps, but its still not really enough.
I just thought of something else too, the SA-8 has a mounting depth of 6 5/8". There is no way to make a box deep enough to mount the sub, unless you used spacer rings to make the sub stick out the front of the box, but then you still won't have a room for a port. If you can't make the box bigger you may just be out of luck.
Builds:
How much power are you going to run?
Builds:
So I just had a thought, would it be possible to reverse mount the sub with the motor on the outside of the box? Would that work with your space?
Builds:
sadly not as would hit the back of the seats. ive been looking at rockford fosgate 8" subwoofers as they have a mounting depth of 4.76" but cant decide which would be better a single dual 4ohm or single dual 2ohm
What amp do you have? Dual 4 ohm will let you wire to 2 ohms of 8. Dual 2 ohm will let you wire to 1 ohm or 4.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 507 Guests (See full list)
