Second Skin Posted April 15, 2016 Report Posted April 15, 2016 (edited) Check out Damplifier and Damplifier Pro B Stock boxes currently in stock.....save big on B Stock factory errors for a limited time only!!! Damplifier and Damplifier Pro B Stock boxes contain the same great high quality butyl rubber and 6.5 mil annealed foil as the regular A Stock, just with factory set up errors such as: wrinkles, rolled edges, and/or thickness inconsistencies of +/- 25%. B Stock Damplifier/Damplifier Pro performs just as well as the A Stock product line, it just has mostly cosmetic errors that are covered up by the next layer of foam or upholstery anyways. Check the in stock B Stock product line here Current B Stock Box Count is: 11 Boxes of Damplifier/Damplifier Pro 40 lb Mixed Piece Box (60-90 sqft) 2 Boxes of Damplifier Pro Shop Packs (90 sqft) 20 Boxes of Damplifier Pro Bulk Packs (30 sqft) 3 Boxes of Damplifier (32 sqft) Here is a video using part of a 40 lb B Stock box on the trunk of a Dodge Avenger Edited April 15, 2016 by Second Skin Quote Whether you are restoring a classic muscle car, building an audio system monster, or trying to give yourself a bit of silent luxury on your daily commute, we have a product or combination of products that will help you achieve your goals while saving money and save time. Look around our site, educate yourself and make the choice that is right for you. Over built to over perform - because user error, bad batch, and faulty install are excuses that other companies use!
Second Skin Posted April 26, 2016 Author Report Posted April 26, 2016 ONly a few boxes left, don't miss out on this round of Damplifier Pro B Stock. Same great high quality materials, just not as pretty as the Damplifier Pro A Stock!!! Quote Whether you are restoring a classic muscle car, building an audio system monster, or trying to give yourself a bit of silent luxury on your daily commute, we have a product or combination of products that will help you achieve your goals while saving money and save time. Look around our site, educate yourself and make the choice that is right for you. Over built to over perform - because user error, bad batch, and faulty install are excuses that other companies use!
