What size fuse do I need?
You fuse to protect the wire, which in turn protects you and your vehicle.
The wire size, type and length are your factors to determine fuse size.
Ok so the amp kit that fits my amp would be a 4awg amp kit and im going to be purchasing it from gpcaraudio so it will be ofhc and the length of the wire is
17 feet 4 AWG OFHC Power wire
3 Feet 4 AWG Ground Wire
Fuse externally for 120A.
The website only has 100A do u think that's close enough or should I grab one from somewhere else to get a 120A fuse?
Yeah, 100A should be fine.
Why, because the amp has 3 40A fuses on it? That has nothing to do with what fuse he should use. Telling him to put a 120A fuse on a 17 ft. run of 4ga is not helping him at all.
OP, use the smallest fuse you can get by with. That's why I asked you if you were running another amp.
Hey I didn't see UR response last time but I only have the stock amplifiers for a Chrysler lhs w/ infinity system the only after market amp will be the 1200watt one otherwise no other amp sorry again I missed UR last comment
  • Who's Online   0 Members, 0 Anonymous, 962 Guests (See full list)
