BoogerMan's 5k SoundQubed build in a 2011 Toyota Camry SE
Top baffle cut out
Wrapped in suede
Installed. Screwed on from the inside of the box
Amps bolted to front of box
Back of battery rack attached
Battery rack installed. It screws into the box under the 4500
Deadener on front floor
1/2" threaded rod through back of the box attached to trunk seal
Steel angle bracket to support top baffle cutout
Wiring
Battery fuses and interior leds
4500 fuses
Underbody LED kit switch by drivers right knee
Interior LED module under driver seat
Remote gain knob
Mounting speaker rings to pod base
Wrapped pods and fiberglassed
2 layers of resin first
3 layers of resin and mat
Sanded and trimmed
3 layers of milkshake
Sanded and test fit
Ensolite foam inside the doors
Mass loaded vinyl
The car has very little road noise
Expanding foam on backside of trunk seal
Deadener in trunk to help vibration and road noise
Did a 149.7 at 38hz for my first meter. The cross braces in my roof were broken and there was zero deadening on the roof at this point. I also wasn't clipping on the gain remote knob so after deadening my roof and pushing the subs a little harder I should be able to break 150. I'm happy with the results for my daily ground pounder.
Pulled the headliner down
Panel bonded the braces back to the roof
Gluing some wood to the roof near the back window with PL 8X. This spot flexes really bad so the wood should help
2 layers of deadener on the roof. I was going to do wood here too but that would make the sunroof unusable so I went with mat instead. Should be okay
Great stuff around the wood
That's it for now. I cut my thumb on a table saw Saturday night so finishing up the roof came to a halt. Luckily I'm okay and didn't need surgery or stitches but my left hand is pretty sore. I have to keep it bandaged the next few days so I still need to get the headliner put back up. I'll post some videos tomorrow.
Feel free to ask any questions! Thanks for looking :D
