2 DC 8 inch box build
Hey guys. Just picked up 2 DC 8 inch subs,,,, the older ones that can be in a sealed box.
I am putting them in a Chevy Blazer and running a Kicker 1000.1 I believe they are dual 2 olms so I would be running the amp at 2 olm.
Which would be louder, more bass? sealr or ported?
Could someone recommend sub box dimensions and port size if ported? I believe that they can run .35 sealed but I want as much as I can get
out of them.
Thanks very much.
ported will be louder around tuning. need to post exact model of sub and max dimensions for box for some box design help.
Sounds good. I will post some pics of the subs later on and the dimensions of the Blazer. There are no model numbers on the subs themselves, just that they are the older ones that were able to be sealed.
So here are some pics of the subs and my blazer of the rear. The width is 38 inches by 15 high where the white amp board is. Depth could be up to 13 inches,,, but I think that is plenty for these 8 inch.
As you can see there are no markings on the sub to indicate what model they are.
Kicker on the left, (missing) surround came off, re glued and then coil went. Kicker on right the spider is breaking... so just going to go
better with the DC.
I know I should be getting bigger subs for this truck but I only have so much cash right now, so the 8's will have to do. I'm sure they
will put out some good bass for the size of them.
  • Who's Online   0 Members, 0 Anonymous, 1610 Guests (See full list)
