box design nvx VCW12
revision 2 here:http://www.stevemeadedesigns.com/board/topic/205007-revised-single-vcw12-enclosure/
new design on post #9
i made a box for a single VCW12 using assorted calculators and such and i was hopeing for opinions
https://dl.dropboxusercontent.com/u/81841488/nvx-VCW12-box.skp is the link to the sketchup file should auto download i belive
2 11" long 3"dia pvc ports (used the http://www.psp-inc.com/tools2.html calculator for tuning) for a tune of 30
sub up port back
any helpfull advise appreciated
thanks to mark from C.A.F. for the sketchup tutorial
Nice job with SketchUp?
How much power are you going to be running? Your port area might be a bit on the low side.
Builds:
About 1200 watts at 1 ohm
Something I should have added is I as worried about the back of the ports being to close to the back of the box
is 4" enough??
No a single 4" port won't be enough, you would need two 4" ports at a minimum or a 30 sq in slot port.
Builds:
I meant the space behind the tubes they are 11" long and the box is 15" deep so that leaves 4" behind the port (actually 3 1/4") I wasn't sure if that would be enough
Generally you want one port diameter of clearance to any internal walls.
Builds:
So I'm just barely in the clear there
  • Who's Online   0 Members, 0 Anonymous, 905 Guests (See full list)
