eyeopeningepisode Posted June 22, 2016 Report Share Posted June 22, 2016 Got some DB DRIVE PRO AUDIO P3 6K Components. These are 8 ohm drivers/mids with 4 ohm tweeters with cross overs. 175 watts rms. Which 4 channel amps will work to power these components sufficiently? How does that work if the drivers are 8 ohm and most amps are 4 ohm. I would imagine that if you put 175 watts rms @ 4 ohms to the drivers, they won't take the 175 due to them being 8 ohm? Any suggestions on amp? I really like the CT sounds 125.4 but it's a bit pricey. I can get a DB DRIVE A7 125.4 for $230 new....is this a good option? How about the Massive Audio D8004 or any other suggestions? Thanks in advance! Link to comment Share on other sites More sharing options...
