4Th Order in Dodge CHarger SRT8 USing JL 12w6v3s
The max width at widest is 40" there is a 2" tall lip on each side that is 4" long. So at the very bottom it will go 32 wide.
Mario knows what I am talking about. If you see the costly charge boxes on eBay they have a 2x2 cutout on the corners of the boxes. I added the space up for that and i
Roughly get .33 cuft.
I was thinking of leaving this space alone to run wires under.
So the max width I could go is 40". The tallest is 16 which is 1/2 in shy of the 6x9's.
The depth I would like to keep it at 17 to get to the amps. But this 17 can added on to
I would like to tune it under 34hz. Like 28 to 34 if possible. Is that doable with using a 8" port? Cause that would perfectly fit my 8" hole in the rear deck where Boston sub was.
Ok.. so with the dimensions u listed, it would be best to only build a ported box.
I kno with the charger box I recently built, I could get 18" tall and 25inches deep and still have 5 inches of clearance from the back..
I modeled a box off of the dimensions I listed before u gave measurements.. and it would work great for a 4th order for 3 12s..
Here's the dimensions I have for the box.. 38 wide (32 wide for the bottom corners), 18 tall (if that will hit ur 6x9s, I'd suggest spacer rings). And 30 deep. I can reduce depth a couple inches if that is too deep, but 25 would doable, it'll just lower ur output some.. I'll be uploading a design in a minute so u can see..
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
The sealed section is 3 cuft. Ported is around 5.85 cu ft.. to determine how much port will be inside the box I will need to kno the distance from the deck lid (above) to the trunk bottom..
1994 Ford Bronco
Sony door speakers
is that with using the rear of the woofers in the vented side? thats alot of cuft for my trunk.thats almost 9cuft i think and my trunk doesnt have that much.
maybe ill stick with your original opinion and just do ported.
The back of the woofers are in the ported section.. and as long as the srt8 has the same trunk as a regular charger, it will fit (just have to assemble in the trunk..
1994 Ford Bronco
Sony door speakers
what would the port size be if its 8" dia?
To determine that, I'll need to kno the distance from the trunk floor to the deck lid (give me the largest measurement since the decklid is probable slanted some..and how far above the deck lid u want the port opening to sit..
I should also clarify that the carpet was removed from the trunk floor in the setup I built.. this may be where the difference in height comes from.. if u don't mind, measure both with and without the carpet..
1994 Ford Bronco
Sony door speakers
  • Who's Online   0 Members, 0 Anonymous, 1437 Guests (See full list)
