Jonathan91 Posted July 13, 2016 Report Posted July 13, 2016 I want to put 2 of these ab 8" in the truck silverado. I dont know what is best a aero or ported box. This is my area i have to work with as you may see in the pic. The Height 1 and Depth can be either one: Ok, so how would it sound if i made it aero port with this specs: 32width, 11height 1, 9height 2, 16depth with only 1 port tube at 12.5 inches in depth and 4 inches in diameter? I got a net volume of 1.92 with 34.24Hz.
Triticum Agricolam Posted July 13, 2016 Report Posted July 13, 2016 What AB subs do you have? Whats your amp? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Jonathan91 Posted July 13, 2016 Author Report Posted July 13, 2016 2 of these https://www.amazon.com/American-Bass-quot-Competition-Woofer/dp/B00H3RK2EM It was actually this amp here i got from offerup http://www.sonicelectronix.com/item_112003_Crunch-PD-2000.2.html
Triticum Agricolam Posted July 13, 2016 Report Posted July 13, 2016 OK, so with that amp lets figure you will get about 600 watts out of it. I would suggest using a slot port since a single 4" aeroport probably isn't going to be enough port area. Two 4" ports would be enough, but they will have to be so long as to be impractical. I'd shoot for 1.5 cubes net volume and at least 20 sq in of port area, 25 would be better. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Jonathan91 Posted July 13, 2016 Author Report Posted July 13, 2016 at OK, so with that amp lets figure you will get about 600 watts out of it. I would suggest using a slot port since a single 4" aeroport probably isn't going to be enough port area. Two 4" ports would be enough, but they will have to be so long as to be impractical. I'd shoot for 1.5 cubes net volume and at least 20 sq in of port area, 25 would be better. Keep in mind the box's height is the average of both sides. This is for the box height set at 10 (Height1- 11" and Height2- 9") ------Best i could do is 1.47 cubes net. Port area of 21.25. Port w-2.5" h-8.5" l-25.5" at 36.5hz This is for the box's height set at 10.5 (Height1- 12" and Height2- 9") ------ 1.72 cubes net. Port area is 22.5. Port w-2.5" h-9" l-25.5" at 34.57hz the displacement for both subs are .146, as for the Height 1 and 2 see the first pic i posted if you get confused
Triticum Agricolam Posted July 13, 2016 Report Posted July 13, 2016 I think either of your planned specs should work just fine. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Jonathan91 Posted July 14, 2016 Author Report Posted July 14, 2016 Ok, turned out i made a mistake on my measurements lol. It had to be 14" in depth not 16". So i went back to the drawing board and this is what i made. I dont know which one to go with. https://s32.postimg.org/4pri3u445/BOX_SPECS.png
Triticum Agricolam Posted July 14, 2016 Report Posted July 14, 2016 I would do the bottom one with the 2.25" wide port tuned to 35 Hz. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Jonathan91 Posted July 14, 2016 Author Report Posted July 14, 2016 What made you pick that one? I was going for the 2.25 with 36hz, but ill go with the one you said lets see how it goes.
Triticum Agricolam Posted July 14, 2016 Report Posted July 14, 2016 What made you pick that one? I was going for the 2.25 with 36hz, but ill go with the one you said lets see how it goes. Well you definitely want the greater port area of the 2.25" wide port, so that rules out half of your choices. A 35 hz tune is a good place to be with those subs, so that's why I picked it. However there isn't going to be a large difference in performance between a 34 or 36 Hz tuning. Any of those choices should work well. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
