akrja_07 Posted August 2, 2016 Report Posted August 2, 2016 I posted a while back about help with an enclosure for 2 type x 12's but switched subs before I could start building the box. I now have two DC level 3 m2 d1 12's going in an extended cab 01 Silverado. I am thinking the enclosure should be around 3 cubes tuned to factory specs or slightly lower. My ideal dimensions are 45 x 15 x 15 but can give or take a few inches from anywhere. From what I understand, subs will perform best is they face up and port faces the side, does that sound right? Also curious if I should do a double baffle and if I should do any bracing... Thanks in advance, once again. 2001 Chevy Silverado Ext. cab - Kenwood KIV-BT901 - 2x 12" DC Audio level 3 m2D1 in 4.2 cuft. @29Hz. - DC Audio 2.0k - Alpine Type-X components - US Amps USA-4300x - XS Power D4700 - Bosch 145a alternator
