lebunt30 Posted August 21, 2016 Report Share Posted August 21, 2016 I have 2 orion 275g4 amps. I dont know if they are for small burps or can they be used for daily use. I want to hook each amp up to a memphis mojo dvc 2 ohm sub and bridge them down to 1 ohm. the subs can handle 1200 watts rms each. I know iam going to need a serious altenator and a battery for each amp to just power these beast. but if anybody knows will i melt these amps running them for long time at 1 ohm mono? Quote Link to comment Share on other sites More sharing options...
3vil Posted August 21, 2016 Report Share Posted August 21, 2016 (edited) First off, I'm sure you've seen this already, but I'm linking it just in case... http://www.oldschoolstereo.com/2011/02/not-really-old-school-orion-hcca-275g4.html I feel as long as you have electrical to support two of those amps they should run daily just fine. Edited August 21, 2016 by 3vil Quote Link to comment Share on other sites More sharing options...
lebunt30 Posted August 21, 2016 Author Report Share Posted August 21, 2016 ok thanks for the feed back. You think 1/0 is big enough wire for the altenator to battery? Quote Link to comment Share on other sites More sharing options...
lebunt30 Posted August 21, 2016 Author Report Share Posted August 21, 2016 (edited) i also have a orion 8004 2 but it wont turn on anymore. i looked at the fuses they look fine. It did have a loose connection on the board where the fuse holder was soldered in , so soldered it and then it wouldn't turn on after that. what do you think it could be? Edited August 21, 2016 by lebunt30 Quote Link to comment Share on other sites More sharing options...
