Thoughts on this QWTL design
10 oz total, spread out through the line.
The amount you need in here in HornResp:
Builds:
Yup.
That total is only there if you are in the "Schematic" view.
Builds:
Yup.
That was my problem. I was trying to look at it in the power menu. So, is it normal for excursion to go crazy right below tuning?
Yup, just like a ported box, below tuning the line unloads and the sub starts to perform like its in free air.
Builds:
I figured that was what was going on. It was just unloading HARD. Like it would be at its lowest at tuning like normal but then not even 1 Hz later would be at Xmax
Yeah, that's due to the size of the line. With a smaller displacement line the increase in excursion would be more gradual. This line is roughly equivalent to a 6 cu ft port box, which is really huge for a 12" sub.
Builds:
Could this be helped by making the line area smaller?
A little bit, but not a significant amount.
The best way to deal with it is a properly set subsonic filter.
Builds:
I'm honestly just thinking about buying an eq for my sub stage. My little baby sub has an in-line highpass crossover at 50 Hz that takes quite a bit if power frim the sub and the big boy is just connected straight to the amp. If I got a decent DSP or whatever for the sub stage I could reduce the peaks in the T-Line, put a specific sub sonic filter on and put a high pass crossover on the little sub without sacrificing power right? Unfortunately the NU3000 I got didn't have the DSP built in or I would just use that and deal with the lower output from my little sub.
  • Who's Online   1 Member, 0 Anonymous, 848 Guests (See full list)
