alibaba Posted September 17, 2016 Report Share Posted September 17, 2016 so i went out today with ampmeter n multimeter to clamp my amp to see what kind of numbers is pushing, its a taramps hd2500, i put the multimeter on the pos n neg on the amp and the clamp around my sub positive n this is the numbers i get 28.9x17.6a=508.64 is that right or am i doing something wrong? if its right then fuck i got a 250a alt, big 3 w/ 1/0 everywhere and currently only 1 xs power 5100 but still it should be pushing out more, also this was at 40hz and the gain about half way, when i went to 30hz i turned the gain up n got slightly beter numbers but not much, what do u guys think the problem is here? 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
MADVIBES Posted September 17, 2016 Report Share Posted September 17, 2016 YOU DID THAT WRONG DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz Link to comment Share on other sites More sharing options...
MADVIBES Posted September 17, 2016 Report Share Posted September 17, 2016 you set the dmm to ac volts correct? you attached it to the speaker wire correct? DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz Link to comment Share on other sites More sharing options...
alibaba Posted September 17, 2016 Author Report Share Posted September 17, 2016 you set the dmm to ac volts correct? you attached it to the speaker wire correct? both were set on ac 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
alibaba Posted September 17, 2016 Author Report Share Posted September 17, 2016 n yes the clamp went on the positive wiire going to the sub, the dmm went on the pos n neg on the amp 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
MADVIBES Posted September 17, 2016 Report Share Posted September 17, 2016 both were set attached to the speaker wire? DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz Link to comment Share on other sites More sharing options...
alibaba Posted September 17, 2016 Author Report Share Posted September 17, 2016 YOU DID THAT WRONG what did i do wrong so i can correct it 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
MADVIBES Posted September 17, 2016 Report Share Posted September 17, 2016 how many wires do you have coming off the amp, speaker wire wise? did you make sure to grab both positive wires if there were more than one? if not you sound like you have it right DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz Link to comment Share on other sites More sharing options...
alibaba Posted September 17, 2016 Author Report Share Posted September 17, 2016 both were set attached to the speaker wire? the dmm went to pos n neg terminals on the amp, and the clamp around the positive wire going to the sub 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
