Zak.vr6 Posted September 20, 2016 Report Posted September 20, 2016 Basically I've used new 4awg from alt to bat/ bat to body/ and alt bracket to body Before doing this I was getting 13.8v at the obd plug Now I'm getting 13.2-3 Both at idle and whilst driving it really don't go up much I cleaned all the Earth points I just don't understand it as my bass is miles better at higher volume Car has a 120amp alt I'm running a 900w rms kenwood mono block amp Yes I know there is a possibility that taking a voltage reading from the obd 2 port is not be best way to check I do have 4/0awg power cables but the 4awg was a nightmare getting it in there without bulging Thank you
Zak.vr6 Posted September 20, 2016 Author Report Posted September 20, 2016 by miles better I mean I've turned up the gain without any distortion
Rich Schenk Posted September 20, 2016 Report Posted September 20, 2016 Why didn't you do alt bracket to battery negative, then battery negative to frame or shock tower. You should also do engine ground to battery negative. Body is usually thin metal and not a good ground On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Zak.vr6 Posted September 21, 2016 Author Report Posted September 21, 2016 I need to wait till I'm back at work to crimp and solder more cable What I've done today is move the Earth from the alt bracket So now it's from the head to the neg to battery And now it's reading 13v!! Lost 0.2v lol I've not been playing the bass loud as running in a new sub I'd just like to understand what's going on there As lost 0.8v bit at a guess gained amperage as no distortion/clipping on higher volume
