01 S-10 Posted April 24, 2008 Report Share Posted April 24, 2008 If I have a 5 volt preout for the sub amp and use a splitter to run 2 sub amps will each amp see 5 volts or 2.5? Quote TDH FTW !!! Link to comment Share on other sites More sharing options...
EricM9104 Posted April 24, 2008 Report Share Posted April 24, 2008 2.5 Quote 2015 Honda Civic LX 4dr | 24k miles Stock H/U and mids/highs Power Acoustik GW3-12" D2 Sub HiFonics BXX1200.1D @ 1ohm Random 2.5^3' dual ported box NVX LOC Stinger wiring throughout 1977 Chevy SWB Cammed 350 Dual exhaust Cheap Wish stereo Link to comment Share on other sites More sharing options...
dodgethis39 Posted April 24, 2008 Report Share Posted April 24, 2008 they should see the same if you have a multi meter you can test just be careful not to touch the ends together Quote Link to comment Share on other sites More sharing options...
dodgethis39 Posted April 24, 2008 Report Share Posted April 24, 2008 its just splitting signal not voltage Quote Link to comment Share on other sites More sharing options...
EricM9104 Posted April 24, 2008 Report Share Posted April 24, 2008 its just splitting signal not voltage Quote 2015 Honda Civic LX 4dr | 24k miles Stock H/U and mids/highs Power Acoustik GW3-12" D2 Sub HiFonics BXX1200.1D @ 1ohm Random 2.5^3' dual ported box NVX LOC Stinger wiring throughout 1977 Chevy SWB Cammed 350 Dual exhaust Cheap Wish stereo Link to comment Share on other sites More sharing options...
dodgethis39 Posted April 24, 2008 Report Share Posted April 24, 2008 if you are worried test and if you need it put in a line driver Quote Link to comment Share on other sites More sharing options...
GHOPPOMAN Posted April 25, 2008 Report Share Posted April 25, 2008 u hardly lose any voltage unless u split alot. my educated guess = 4.9 each Quote Link to comment Share on other sites More sharing options...
01 S-10 Posted April 25, 2008 Author Report Share Posted April 25, 2008 Thanks for all the replies, just curious because I don't have a voltage meter at the moment Quote TDH FTW !!! Link to comment Share on other sites More sharing options...
missinglink Posted April 30, 2008 Report Share Posted April 30, 2008 At spring break nationals we found out if you daisy chain over 4 amps you will lose some signal. Hope this helps some MLA Quote missinglinkaudio The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander... Link to comment Share on other sites More sharing options...
GHOPPOMAN Posted May 1, 2008 Report Share Posted May 1, 2008 At spring break nationals we found out if you daisy chain over 4 amps you will lose some signal. Hope this helps someMLA sounds right....thats why i run 8 volt out rca split to 8 amps Quote Link to comment Share on other sites More sharing options...
