Wall build questions
dsw422
Hey guys.. getting ready to build a wall in a 98 4 door accord for 4 sa 15s.. Question I have has to do with panel strength..
When building the sides of the wall and the back above the rear deck, is 1 sheet of mdf with 2x4s glued and screwed to the outside strong enough to keep from flexing?
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
your biggest prevention for flexing is going to be bracing within the box. although I believe wall density is a premium when building a box, the most important factpr is box bracing.
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
Ok.. so I'll go ahead and do double layer all the way around. 2x4 on the outside of the sides and back as well as internal bracing... thanks.
1994 Ford Bronco
Sony door speakers
  • Who's Online   1 Member, 0 Anonymous, 3718 Guests (See full list)
