Thanks guys. Someone told me that it takes up space by fiberglassing the inside...so does this mean my bass won't get as low?
2008 Chevy Impala (undercover cop style)
Setup in the makings
ya its going to take up a little room but not much. depending on how many layers you do and how thick the mat is, you could mesure the thickness of it and add that to the thickness of the wood, recalculate and then you have your answer if you wanted to be really precise. but just adding 3 or 4 layers to stregthen a box isnt gonna take up that much space and probably not make a noticable difference in sound (at least not to the ear)
x2.
if you think it might cause a problem you can always build up the matt outside the box...granted its more finish work but its always an option.
