Joshua Learn Posted November 8, 2016 Report Posted November 8, 2016 Just purchased one. Need to build an enclosure. Space really isn't an issue. I'd like to stick to all wood port no aeroport. I like to listen to rap metal and rock most of the time I do like low notes but I like the hit of the kickdrums. Running on Alpine mrp-m100.
Triticum Agricolam Posted November 8, 2016 Report Posted November 8, 2016 Realize that there isn't one single "optimal" enclosure spec for any sub that will be the best in all situations. Every install is different and every person has different goals. What will be best for YOU depends on what kind of vehicle you have, what you listen to, what your goals are, how you like your music to sound, etc. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Joshua Learn Posted November 9, 2016 Author Report Posted November 9, 2016 Realize that there isn't one single "optimal" enclosure spec for any sub that will be the best in all situations. Every install is different and every person has different goals. What will be best for YOU depends on what kind of vehicle you have, what you listen to, what your goals are, how you like your music to sound, etc. Ok the nvx site list recommed box volume at 2.5 cubes @33hz tuning. Should i stick to these numbers? Or how reliable do you think NVX is on box reccomendations?
Triticum Agricolam Posted November 10, 2016 Report Posted November 10, 2016 This is going into a truck right? Since you want to have good low frequency output I would probably tune a bit lower than 33 hz, 28 Hz would probably be a good place. Lowering your tuning frequency will reduce your peak output bit, increasing box volume can compensate. I'd go with 3 cu ft. Assuming 1,000 watts of input power you would want a minimum of 35 sq in of port area. 40 sq in would probably be better. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Joshua Learn Posted November 10, 2016 Author Report Posted November 10, 2016 Ok I'll have to go back and redesign my enclosure. I was working it out last night and I got it to 3.2cubes net and 29hz tuning but that was at 25in2 of port area. 5x5 square port would be too restrictive? Not slot but a literal square. I'll go back and try to bump it up to 6x6 port tonight if you think that'd yield better results.
Triticum Agricolam Posted November 10, 2016 Report Posted November 10, 2016 No, a 5x5 port will not be big enough. A 6"x6" port would be the minimum. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Joshua Learn Posted November 10, 2016 Author Report Posted November 10, 2016 And yes it is going in a 97 Chevy ext. Cab full size. And it's on an Alpine mrp-m100.
Joshua Learn Posted November 11, 2016 Author Report Posted November 11, 2016 Would this be about correct if I change to slot port? that comes to 49 in2 ish. http://prntscr.com/d5rmb4
