Cwallaker Posted December 6, 2016 Report Posted December 6, 2016 I have a p1000x1 amp . It has L&R outputs .If I get a smd 2 chanel terminal cup that has ch1 &ch2 then wire L&R from the amp to them . Then run ch 1 to one vc ,and ch 2 to the second . Will the amp se this as a dvc in series . For me this will equal a one ohm load . If this seems like a stupid quesion ,laugh and then give me a straight answer. I wouldn't have asked if I Knew for sure . Thanks ...
Jessica Posted December 6, 2016 Report Posted December 6, 2016 both outputs are the same channel, and you mean parallel not series, and yes if it is a d4 sub Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Cwallaker Posted December 6, 2016 Author Report Posted December 6, 2016 both outputs are the same channel, and you mean parallel not series, and yes if it is a d4 sub
Cwallaker Posted December 6, 2016 Author Report Posted December 6, 2016 Whoops ,yes parallel. Thanks man .
Jessica Posted December 6, 2016 Report Posted December 6, 2016 sorry, i mean if its a d2 sub it will see 1 ohm, a d4 it will see 2ohm Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Cwallaker Posted December 6, 2016 Author Report Posted December 6, 2016 Also it's a dual 2ohm ssa xcon . So parallel it'll see 1 ohm correct?
Cwallaker Posted December 6, 2016 Author Report Posted December 6, 2016 Thanks for a quick , and clear answer . Cheers !
SkarredSierra Posted December 6, 2016 Report Posted December 6, 2016 http://www.the12volt.com/caraudio/woofer_configurationsm.asp I use this site to double check myself.
