Box design help!!!
Strokerjoe
Then you'll probably want to be tuned about where you are if not a bit lower. Again, also depends on the driver itself. They most likely recommend it be tuned at 49Hz because that is when it will be loudest in their recommended box size. Problem with that is you'll likely see the response roll off pretty high and your cabin can only boost so much. This is good for listening to bass guitars or kick drums but most hip hop/rap have beats that go lower than that. If you really wanted to you could make a box with an adjustable port that way you could dial it in to what you want.
  • Who's Online   1 Member, 0 Anonymous, 1188 Guests (See full list)
