Rockford Fosgate Power T2 5.25's in a '99 Toyota Tacoma - Custom Door Adapters (CNC)
meade916
Brandon is just now getting to his mids/highs in his Toyota. He already has some older (real old) MB Quart Coax's in there but is ready to upgrade to some Rockford Fosgate Power T2 5 1/4's. He is also going to put a set in his kicks too. Right now, getting these in the doors was the first step.
Once the original plastic was taken out, i took a look at it and got busy on the computer. I drew up a replacement on CAD and milled it out on my CNC. They worked great. The only downside was we had to grind some of the integrated ring on one side so the door panel would clear. It is a FINE LINE between the speaker hitting the window track and the adapter plate hitting the door panel The only solution was to grind as you will see in the pics.
THIS IS NOT DONE YET! I will update it as we get the rest installed.
Follow my Tweet (Twitter)
ill post more updates...these things will be sealed in nicely with Second Skin Damp-Pro. He just needs to wire up his crossovers and they are ready to fire up!
again, it sucks i had to grind them. Well i ground the smoother one down, brandon ground the "other" one down (you guess the one he did haha).
But they clear now and he is good to go.
here is a short little video clip. Nothing worth you-tubing just yet.
https://www.facebook.com/SteveMeadeDesigns/videos/10154837775603430/
  • Who's Online   1 Member, 0 Anonymous, 1417 Guests (See full list)
