clipping
if i look at a track in audacity if it onley has 4-6 very skinny red lines is this still a throw away or is it ok being such a small amount
this is my first build, i have been waiting 4-5 years to have this done
95 chevy 2 door tahoe 5.7
Xs power d3400
Singer 275amp alternator
Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders
Sundown SAE-1500d
Mbquart onyx OA800.4
Stinger 4400 series RCAs and stinger volt meter
Fi Q NEO 18, 7.5 cubes tuned 32hz
Pioneer MVH-X690BS H/U
Kicker CSS 6.5 comp sets in front doors
Kicker KSC 4x10 coaxials in rear
GTMAT and FAT MAT deadner
Xenon 10k Blue HIDs
Should be fine. It's probably only clipping on a high frequency note and your sub won't play those frequencies because you'll set your "Low Pass Filter" either via amp or on your headunit settings to like 80Hz. This means it will only pass signals from 80 Hz or lower. Anything higher than 80Hz your sub will filter out.
Should be fine. It's probably only clipping on a high frequency note and your sub won't play those frequencies because you'll set your "Low Pass Filter" either via amp or on your headunit settings to like 80Hz. This means it will only pass signals from 80 Hz or lower. Anything higher than 80Hz your sub will filter out. Edit: It will not entirely "cut off" the signal but rather, it will 'roll off' meaning some of the signal will stay get in.
Ok cool cause a lot of songs I like inlet have a few spread out
when you check a song with audacity an is no or little to none red you are in the clear for sure ?
Xs power d3400
Sundown SAE-1500d
Xenon 10k Blue HIDs
  • Who's Online   0 Members, 0 Anonymous, 702 Guests (See full list)
