Skar EVL15 in a Spark
la_01ninja
Hello all... been a while since I've been on here but I'm ready to come back!!! Picked up a Skar EVL15S 15 d4 and a Skar LP-1000.1 to cram into the back of my 2016 Chevy Spark. Need box ideas/ suggestion/ design... my max space is 30w x 12d x 22h.
Sub specs are:
  • Skar Audio EVL-15 D4 15" Competition Car Subwoofer
  • Dual 4 Ohm
  • RMS Power: 1,250 Watts
  • Peak Power: 2,500 Watts
  • Voice Coil Size: 3"
  • 4 Layer Black Aluminum CCAW Voice Coil
  • Frequency Response: 15-250 Hz
  • High Roll Foam Surround
  • Sensitivity: 86.1 dB
  • Fs: 36 Hz
  • Re: 3.8 Ohms
  • Qms: 5.04
  • Qes: 0.89
  • Qts: 0.75
  • Mms: 324.5 g
  • Cms: 0.059 mm/N
  • Bl: 12.8 n/a
  • Vas: 51.1 L
  • Sd: 779.3 cm^2
  • Xmax: 24mm (one-way)
Thank you once again for y'alls help!!
You are at 3.3 cu. ft. before any displacements, so sealed is your only option and that will be undersized a bit.
1 hour ago, la_01ninja said:
I do have room for a wedge if I went 12d at the top and 18d at the bottom. Also I van go a bit wider to 32w if needed.
Correction.... absolute max is 36w, 12d top, 14d bottom, 26h... just re-measured the little area I have... Skar does however recommend 24w, 16.7h, 14.4d... that's what I've been going off of to be honest...
  • Who's Online   0 Members, 0 Anonymous, 1376 Guests (See full list)
