Running Different Batteries
i asked my local dealer here and they say that running a negative wire from the yellowtop(hood) and the kinetik(back) will have a minimal effect, so he said he won't put one.
It is recommend to run a negative i have basically the same setup as you have. 1 Yellow top under the hood and 1 HC2400 in the rear 1 run of 0/1 negative and 1 run of 0/1 positive
Ive asked a friend of mines do i need to run - batt wire to my batt in my trunk he told me no cause i have a full frame car ((89 Caprice))an dat u only need to do dat if you have a unibody
I think you may be confused. By the "frame" he means chassis. That's the best ground I can think of
hmm... copper vs steel? i pick copper. if you have the money that is. copper conducts electricity way better than steel. yea it will work but not as good as it can. look at all of the big dawgs on here. they all have at least a pos and neg running to the back.
just my .02
Need any thing chromed? Hit me up!!!
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
from here: RollinSoLow, Derrick824, Ray
from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
This may be a stupid question but what is your factory ground from the battery up front connected to. Some where on your car copper will have to touch steal for a ground right. I may be wrong.
missinglinkaudio
The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
MLA, I've been saying that for the longest. Some people don't look to see where their factory ground is connected to. IMO, ground is ground is ground is ground. as long as you upgrade the stock wiring there's no need to run a wire all the way from the front battery to the back battery.
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
Grounding to the chassis will work, but depending on the current draw, a copper 0 gauge cable could be a better conductor. Unless you are competing, I wouldn't worry about it.
BTW, it is OK to mix battery types, and it won't be any harder on the alternator than adding an extra battery of any other type.
  • Who's Online   0 Members, 0 Anonymous, 577 Guests (See full list)
