4th oder sundown sa 12s box help
Looking at the pics it looks like a fairly high ratio design.  So what are the specs on the box?  Chamber sizes/tunings?
How much power are you going to run?
What vehicle is this going in?
What kind of usable frequency range are you trying to get?
Builds:
20 minutes ago, brian85578 said:
2 sundown sa 12s on a sundown saz2500d ratio 2 to 1 vehicle toyota Camry tuned to 46hz like to get 25 to 60hz
What are the chamber sizes after displacements?
Builds:
11 minutes ago, brian85578 said:
i dont know is there any way you could figure it out for me i know the subs take up .14 each
Yeah I can figure it out, but I won't be able to get to it until later.
Builds:
Ok, here are the specs I got from the pictures:
Sealed side - 1.6 cu ft (.8 each)
Ported side - 4.4 cu ft
Tuning - 45 Hz
The frequency response is pretty peaky, I don't know if you will the bandwidth you want, but it won't be real far from it.
An 8" aeroport is not big enough, if you want to use an aero port you need to use a 10".
Builds:
  • Who's Online   0 Members, 0 Anonymous, 1358 Guests (See full list)
