Four sa10d2 enclosure help needed.
Aaskia
Hello everyone, I'm new to the site, but I was wondering if I could get some assistance.  I tried playing around with winisd to create a box, but maybe I'm not going about it the correct way.
So here is my situation.  I have four SA10-D2 that I am going to wire up to a 1 ohm load all powered by a hifonics brx4016.  I plan on installing this into my 2010 dodge challenger.  Here are the specs on the subs.  Im looking for help in designing a ported box.  1-1.25 cubic foot per sub, tuned around 35hz.  My working dimensions are 36"width, 24" depth, and 12" height.  All done with 3/4 mdf.  I have a full sheet of mdf in the bed of my truck and my wood working skills are good.  Its just designing the box that I need help with.  Thank  you in advance.
Specifications SA‐10D2
RE (ohms) 4.29
FS (Hz) 35.4
Vas (L) 10.13
Qes 0.52
Qms 5.41
Qts 0.48
Le (mH) 3.41
BL (NA) 20.40
Mms (Grams) 230
Cms (uM/N) 87.8
Sens (1w/1m) 81.0
A little background on the rest of the system thats going in the car.
Image dynamics cxs64 in the front active
Image dynamics 6.5 mids in the rear deck
Minidsp plus the usual other goodies
I listen to a wide range of music. Mostly metalcore, rap,  but I also play the piano,  so you might hear someYanni.
Based on the dimensions you gave you don't have enough space.
You could build a sealed box to fit those dimensions, but not a ported one.
Builds:
This is the dimensions of the trunk. The 40" width i cut down to 36" because of the hump at the bottom of the wheel well. My dimensions in my first post were conservative.   I can use  as much trunk as needed,  just need to make sure I have room for 3 amps.
  • Who's Online   0 Members, 0 Anonymous, 1530 Guests (See full list)
