Aaskia Posted June 20, 2017 Report Share Posted June 20, 2017 Hello everyone, I'm new to the site, but I was wondering if I could get some assistance. I tried playing around with winisd to create a box, but maybe I'm not going about it the correct way. So here is my situation. I have four SA10-D2 that I am going to wire up to a 1 ohm load all powered by a hifonics brx4016. I plan on installing this into my 2010 dodge challenger. Here are the specs on the subs. Im looking for help in designing a ported box. 1-1.25 cubic foot per sub, tuned around 35hz. My working dimensions are 36"width, 24" depth, and 12" height. All done with 3/4 mdf. I have a full sheet of mdf in the bed of my truck and my wood working skills are good. Its just designing the box that I need help with. Thank you in advance. Specifications SA‐10D2 RE (ohms) 4.29 FS (Hz) 35.4 Vas (L) 10.13 Qes 0.52 Qms 5.41 Qts 0.48 Le (mH) 3.41 BL (NA) 20.40 Mms (Grams) 230 Cms (uM/N) 87.8 Sens (1w/1m) 81.0 Link to comment Share on other sites More sharing options...
Aaskia Posted June 21, 2017 Author Report Share Posted June 21, 2017 A little background on the rest of the system thats going in the car. Image dynamics cxs64 in the front active Image dynamics 6.5 mids in the rear deck Minidsp plus the usual other goodies I listen to a wide range of music. Mostly metalcore, rap, but I also play the piano, so you might hear someYanni. Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted June 21, 2017 Report Share Posted June 21, 2017 Based on the dimensions you gave you don't have enough space. You could build a sealed box to fit those dimensions, but not a ported one. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
Aaskia Posted June 21, 2017 Author Report Share Posted June 21, 2017 This is the dimensions of the trunk. The 40" width i cut down to 36" because of the hump at the bottom of the wheel well. My dimensions in my first post were conservative. I can use as much trunk as needed, just need to make sure I have room for 3 amps. Link to comment Share on other sites More sharing options...
Aaskia Posted June 21, 2017 Author Report Share Posted June 21, 2017 I'm not opposed to doing a sealed box. But if i have the room, i wouldn't mind going ported. I want spl, but i also love great sound quality. The trunk has a height of 17 inches. Link to comment Share on other sites More sharing options...
Aaskia Posted June 28, 2017 Author Report Share Posted June 28, 2017 Man maybe I'm an idiot, but I can't seem to get this winisd down. Any help, please. I have 32x24x15 to work with. I have no tunes and I'm ready to build this box. Thanks. Link to comment Share on other sites More sharing options...
