Check numbers please?
Bonka
I think I didn't factor that 3/4" in but there's still a huge difference in the box volume. You're not supposed to count the port volume in the box volume correct?
i get 1.97cuft net using sketchup. here is the port lengths for a 28" long physical port. end correction not included. you could make the port about a half inch shorter and it would probably act like a 28" port
Ok so I definitely did mess up that 3/4" on the port length and I miscalculated the volume  of that dotted section I had in my drawing because I didn't factor in 3/4" there either. I'm now coming to the 1.97 ft^3 you came to. That's roughly 33.25hz. I think this should actually be ok. I know SA recommends 35hz but I've seen people doing 33hz. If not I can recalculate to get closer to 35hz. Thanks for the helping me figure out what I botched there.
I'm getting the Hifonics Brutus BRX1100.1D which can put out 800w at 2ohm. I guess I could add more length to the port since the area is a bit low then.
you would have to make the port bigger and box bigger and yes, port longer. You might have some port noise at tuning. Not to knock that amp but i think you will be fine. its fused at 60amps so i doubt it would do more than 750 even at 1ohm. doubt it will do 800 at 2ohm
  • Who's Online   1 Member, 0 Anonymous, 2619 Guests (See full list)
