Math check on sa 12 box
I am wondering if someone would be willing to check my math on this enclosure for 2 sa 12's
14.25" h
30.25w
12" depth 1
15" depth 2
(wedge enclosure)
3/4" material
= 2.55 ^3ft internal air space
Sa's will displace .28^3 leaving 2.77^3
To achieve 35hz tuning, aero port will be 4" diameter by 9.25" long
port displacement V = radius x pi x length = 4^3 x pi = 50.26 x 9.25 = 464.9 ( 465 cubic inches) - converted to .269 cubic feet rounded to .27
so remaining displacement of 2.77 will end up being 2.0^3 after port displacement
I get 2.21 cu ft net after sub and port displacements.
That's too small for a pair of SA-12s and like strangeduck said, no where near enough port area.
Here is a port area calculator to help you get a better idea how much port area you should have: https://goo.gl/STAv4p
Builds:
What I am thinking is a new design that is 4.243 net volume
3.96 cubes after woofers
I need at least an 8" port for 50 cubic inches roughly as my minimum port area is 47 with 1600watts, and tuned to 35
My question is, if I have 3.96 cubes to work with, an 8 inch port internally will take up 22 inches and displace too much
can I mount two 4 inch aeros internally to make that 8" area up? they will only be roughly 4 inches long and take .11 cubes of displacement each leaving 1.87 cubes per woofer
or I can mount the 4 inches externally to leave 1.98 per woofer
Here is where I think I land best
Height 14.25
Width 30.25
Depth1 22
Depth2 25
4.66 cubic feet = 4.38 after sub displacement (.28)
Port Diameter (D) 8    Box Volume (Vb) 4.38    Tuning Frequency (Fb) 35hz         Port Length   19.4
Pi(r)^2(height)/1728
3.14 * 16x19.4 = .56 displacement
4.38 - .56 = 3.82 = 1.91 per woofer
How does that look?
  • Who's Online   0 Members, 0 Anonymous, 2822 Guests (See full list)
