Dragonware Posted November 19, 2017 Author Report Share Posted November 19, 2017 Update . Re siliconed inside the box used weather stripping and went straight into the wood with screws. Now when i push in one sub the other comes out so id thing i have a seal ? My Build log : http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/ Current System 2020 Ford F-150 XLT Supercrew Audio Control Epicenter Audio Control LC7i Taramp PRO 2.6 DSP Taramp DS4x800 - Highs Taramp HD3000.1 Mids Taramp MD5000.1 Bass 8 x DS18 6.5 Pro x6m - mids 2 x Soundsteam SST-05 Bullet Tweeter 2 x DS18 TW220 Super Tweeters 4 X SkarAudio EVL-8 BASS Big 3 Yellow Top Link to comment Share on other sites More sharing options...
Jonathan Mills Posted November 19, 2017 Report Share Posted November 19, 2017 Right on that's good to hear what did you end up using? I have heard of mixing saw dust and wood glue and that it works really well. Link to comment Share on other sites More sharing options...
Dragonware Posted November 20, 2017 Author Report Share Posted November 20, 2017 On 19/11/2017 at 5:17 AM, Jonathan Mills said: Right on that's good to hear what did you end up using? I have heard of mixing saw dust and wood glue and that it works really well. Woodfiller and silicone and the weather stripping My Build log : http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/ Current System 2020 Ford F-150 XLT Supercrew Audio Control Epicenter Audio Control LC7i Taramp PRO 2.6 DSP Taramp DS4x800 - Highs Taramp HD3000.1 Mids Taramp MD5000.1 Bass 8 x DS18 6.5 Pro x6m - mids 2 x Soundsteam SST-05 Bullet Tweeter 2 x DS18 TW220 Super Tweeters 4 X SkarAudio EVL-8 BASS Big 3 Yellow Top Link to comment Share on other sites More sharing options...
mpulford311 Posted November 20, 2017 Report Share Posted November 20, 2017 The only thing about screws is that if you keep taking them out and putting them in obviously the holes will stretch out then you'll have to rotate the sub. How thick is your mdf. If it's 3/4 you shouldn't have a problem with t-nuts you just have to be careful. You could try hammer in insert nuts. I have used these before. Good luck on your decisions Link to comment Share on other sites More sharing options...
