Rockford Fostgate p3
Myzv
Hi everyone.
Im using RF p3 d4 @2ohm X2 at behringer ep4000 stereo mode.At home.
P3's working at  sealed  box.
But i vant to create slot port box.
I need  yours advice for slot port box.
1 p3 working.
It depends how low you want to be able to play, and how much power you want to put to it.
2.5 cu ft tuned to 25 Hz would be a decent starting point and should be good for up to about 600 watts with appropriate port area (I'd suggest no less than 30 sq in, the port will be long).
Builds:
I have much power than 600w.
Behringer ep4000 2x900w@2ohm.
I want to listening "bass i love you"max spl ? and max low frequency productivity.
If you tune the box to 30 Hz and shrink the net volume to 2.0 cu ft you should be OK on 900 watts.  You will sacrifice some low end output though, everything is a trade off.
Builds:
Thank you so much.
Can you advise for box and port dimensions pls.?for 30hz tuned.
I have reviewed the forum. There are many useful titles. but the subject is complicate.And my english is not enough. This is the reason for your request for help with boxes and ports.
On 31.01.2018 at 5:33 PM, Triticum Agricolam said:
I dont understand this dimension.
Im calculate Length:42cm Width:45cm and Height:42cm box dimensions.Total:61gross litres.
port Length:30   width:3    Height:30cm  36,3hz tuned
The question that comes to mind is the length of the question mark in the picture.
  • Who's Online   0 Members, 0 Anonymous, 1209 Guests (See full list)
