Jcoleman134 Posted May 1, 2008 Report Posted May 1, 2008 How would i check my woofers ohm load using a digital multimeter? subs a dual 1 ohm.
mrwigglezdj Posted May 1, 2008 Report Posted May 1, 2008 with a multi meeter, set the meeter to the seting that has the ohm symbol, and put the test leads in their proper place (if not built in) and put the red lead on the pos and black lead on the neg, the meeter should show the ohm load for the sub, if you have nothing on one coil check the other and if you have a reading then you know one coil is bad, Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
