Next-LCD
Multifunctional spectrum analyser
  • Completely autonomous
  • Internal battery
  • Graphic display with back light
  • Two Lab-Bus ports for connecting sensors
  • Built-in signal generator (sine, noise)
  • Updatable software
  • Transmitting data to PC
  • Wi-Fi support (optional)
Next-LCD - completely autonomous, all-purpose measuring device
Download Spl-Lab
Video
Description
The Next-LCD is a completely autonomous, all-purpose measuring device. All measured characteristics are displayed as digits and graphs on-screen. The closed software environment of the device eliminates inaccurate readings. The device has two Lab-Bus digital bus ports to which the pressure sensors, microphones or power sensors can be connected. All this makes Next-LCD an all-purpose and completely cascadable tool. When a user purchases, for example, this set for measuring sound pressure, in the future they can supplement it with our microphone for measuring AFC or with our power sensor for measuring current and voltage. Simultaneous work with two signal sources is possible. The built-in sound signal generator of different waveforms (sine, white noise, pink noise) works in background mode alongside the process of measuring. The Next-LCD can be connected to a PC for controlling the device and transmitting data via USB, for example, when it is necessary to display the measurement results on a big screen. The device can be fitted with the built-in Wi-Fi module for connecting to Wireless networks which allow transmitting measurement data for long distances via the Internet in real time mode.
Software characteristics
  • The SPL mode for measuring sound pressure peak values with possibility of displaying the spectrum and waveform of the measured signals. Simultaneous work with two signal sources. Distortion (clip) detector
  • The AVG mode for measuring the weighted time-average value of a sound pressure. Simultaneous work with two signal sources
  • The RTA mode for measuring AFC with possibility of displaying the spectrum and waveform of the measured signals. Displaying with breaking the spectrum into octaves. Distortion (clip) detector
  • The PWR mode for measuring alternating/direct current and voltage, power, frequency of the signal, non-linear distortion (clip) coefficient. Simultaneous work with two signal sources
  • GEN mode. Background stereo generator of test signals: sine, pink noise and white noise
  • The CON mode for connecting with PC. Allows performing customization and transmission of the digitized data for detailed analysis in Measuring Center for Windows
Ergonomics
The Next-LCD device is performed as a monoblock that has graphic display with back light, 8 control buttons, USB port for connecting to a PC and for charging the device, two Lab-Bus ports for connecting sensors, two RCA type outputs of the sound signal generator, feed switch and three-coloured LED for indicating status and extent of battery charge. The device can be supplied with the built-in Wi-Fi module for connecting and managing via the local network. The case of the device is made of shockproof plastic material.
Functions
  • Measuring sound pressure using Next-Lab SPL Sensor
  • Measuring AFC and performing a spectral analysis of the signal using Next-Lab RTA Microphone
  • Measuring power characteristics of direct and alternating current circuits using Next-Lab Power Sensor
  • Possibility of simultaneous work with two signal sources
  • Work of the sound signal generator in the background alongside the process of measuring
  • Displaying the signal waveform and spectrum onscreen
  • Displaying the measured values in digital form onscreen
  • Possibility of controlling the device and transmitting data to a PC via USB port or wireless network
  • Measuring the characteristics of home, car or concert hall acoustic systems and setting them up
  • Measuring the characteristics of home, car or industrial power supply networks and setting them up
  • Preparation and holding of autosound contests of any format (AMT, EMMA , dB Drag, IASCA, BassRace, etc.), as well via the Internet (optional)
Package Contents
  • Main unit
  • USB connection cable for charging and connecting it to a PC
  • Spl-Lab Measuring Center software for Windows
  • Audio-CD with audio tracks for tuning (sine, sweep-tones, noise)
Next-LCD
Next-USB
All-purpose multichannel measuring device
  • Four Lab-Bus ports for connecting sensors
  • Data transmission to a PC, tablet PC, or smartphone
  • Inbuilt battery (optional)
Next-LCD -All-purpose multichannel measuring device
Description
The Next-USB device is intended for transmitting data received from Next-LAB sensors to a PC, tablet PC, or smartphone. As opposed to Next -LCD, this device does not have the inbuilt display and can not be used for independent work. The main advantage of Next-USB is that it has four independent Lab-Bus ports for connecting pressure sensors, microphones or power sensors. It makes Next-USB really an all-purpose and completely cascadable tool. When user purchases, for example, a set for measuring sound pressure, in future they can supplement it with the microphone for measuring AFC or with the power sensor for measuring current and voltage. Simultaneous work with four signal sources is available. For controlling the device and transmitting data from Next-USB, the device can be connected to the PC via the USB or, if the Wi-Fi module is installed, via wireless network to a tablet PC, or smartphone.
Ergonomics
The Next-USB device is performed as a monoblock that has the control button, USB port for connecting to the PC and charging the device, four Lab-Bus ports for connecting sensors, feed switch and three-coloured LED for indicating status and extent of battery charge. The device can be supplied with the inbuilt Wi-Fi module for connecting and managing via the wireless network. The case of the device is made of shockproof plastic material.
Functions
  • Measuring the sound pressure using Next-Lab SPL Sensor.
  • Measuring AFC and performing a spectral analysis of the signal using Next-Lab RTA Microphone.
  • Measuring the current-voltage characteristics of direct and alternating current circuits using Next-Lab Power Sensor.
  • Possibility of simultaneous work with four signal sources.
  • Possibility of controlling the device and transmitting data to the PC via USB port or wireless network (optional).
  • Measuring the characteristics of home, car or concert hall acoustic systems and setting them up.
  • Measuring the characteristics of home, car or industrial power supply networks and setting them up.
  • Preparation and holding the autosound contests of any format (AMT, EMMA , dB Drag, IASCA, BassRace, etc.), as well via the Internet (optional).
Package Contents
  • Main unit
Next-USB
  • Who's Online   0 Members, 0 Anonymous, 3159 Guests (See full list)
