Smart Voltmeter – digital car voltmeter
Car voltmeter with protection feature
  • Compact case
  • Bright three-segment display
  • Measuring voltage up to 18 Volt
  • Three working modes
  • Measurement speed up to quarter second
  • Maximum or minimum peak hold mode
  • Protection feature
  • 3 ampere relay for controlling circuit
Download Spl-Lab
Description
Spl-Lab Smart Voltmeter - is multifunctional digital car voltmeter. Although most of car electronics manufacturers state that their products have inbuilt protection from supply voltage sags or swells, in actual practice it turns out that not every, even expensive, amplifier is able to cope with this task. It means that another voltage overrun can end with expensive repairs or buying new unit. But if you add to your system an inexpensive device from Spl-Lab you can forget about such problems once and for all. Main functions of the Smart Voltmeter are the following: measuring exact characteristics of a car electric network voltage, analysing voltage sags and swells that appear in the operation process of car electronics, protection of electrical equipment of a car from breakage, possibility of flexible settings and easy use. The voltmeter can easily change data refresh speed on-screen (from once a second to once per quarter second), which allows excluding the unnecessary details or to making measurements with maximum possible accuracy. The device has three working modes that can be changed with just one button: voltmeter mode; voltmeter mode with sag and swell indication; voltmeter mode with sag and swell indication and protection feature. For indicating current mode there is a three-coloured LED. User can easily set permissible voltage range for setting the electrical equipment. In the sag and swell indication mode the car voltmeter displays current voltage and in case if the permitted range is overstepped, the voltmeter will inform the user about it by holding maximum or minimum value onscreen for evaluating the degree of sag or swell. In the protection mode in case if the permitted range is overstepped, the voltmeter will break the remote controlling circuit before user’s interference, and protect electrical equipment from breakage in doing so. It stands to mention that Smart Voltmeter is able to commutate the Remote controlling circuit with current up to 3 ampere, and by that to replace an additional relay in case of necessity
Ergonomics
Spl-Lab car voltmeter has compact case, including a three segment display, 4 control buttons, three coloured LED for indicating active working mode and slot for five contacts that has several variants of connection to the electric system of a car. The design of the device allows including it practically in any car interior.
Functions
  • Voltmeter mode - the device simply reflects current voltage values. The controlling circuit is closed.
  • Voltmeter mode with sag and swell indication - the device displays and checks the value of measured voltage for correspondence with the range set in configuration. If the voltage oversteps the defined range, the device comes into the pick hold mode changing the value on-screen only in case if value becomes even lower (primary overswing on the range lower limit) or higher (primary overswing on the range upper limit). The controlling circuit is closed. LED and display start to blink until the Reset button is pressed.
  • Voltmeter mode with sag and swell indication and feature of breaking the controlling circuit - the device displays and checks the value of measured voltage for correspondence with the range set in configuration. If the voltage oversteps the defined range, the device comes into the pick hold mode changing the value on-screen only in case if value becomes even lower (primary overswing on the range lower limit) or higher (primary overswing on the range upper limit). The controlling circuit is broken, LED and display start to blink until the Reset button is pressed.
Smart Voltmeter
  • Who's Online   0 Members, 0 Anonymous, 3159 Guests (See full list)
