Spl-Lab Software - "Measuring Center" for iOS, Android and Windows
Measuring Center for Windows
The software for the spectral analysis of the sound signals
  • Is provided free
  • Simple interface
  • Low system requirements
  • High speed of work
  • Unique algorithms
  • Compatible with Windows XP,Vista,7,8 (32 and 64 Bit)
  • Work with two displays
Measuring Center Software
Description
NThe Measuring Center software for Windows is a multifunctional measuring centre for sound spectral analysis. This software has been created especially for work with Spl-Lab equipment; therefore it will not require additional calibration for taking accurate measurements. The Measuring Center includes profiles for work with each of Spl-Lab devices, you need only to choose the type of the device and you will have accurate data on screen. Version for Windows allows using all might of personal computer and at the same time is not demanding to the hardware configuration. Program will be suitable both for a novice and professional. The program interface is intuitive, you can start measuring at once using the standard algorithm settings, and to perform more detailed setting of Measuring modes according to your preferences. The Measuring Center for Windows software is supplied free of charge complete with the Spl-Lab equipment.
Functions
  • Measuring the amplitude-frequency characteristic (AFC) of the signal - displaying the spectrum
  • Displaying the signal waveform
  • Measuring the sound pressure level with adjustable algorithm (SPL, dB Drag, IdBL, ESPL, AMT, etc)
  • Linear, logarithmic and octave view of spectrum
  • Measuring the amplitude and frequency of the peak values of the spectrum
  • Algorithm of smoothing spectrum in time
  • Quantitative evaluation of the frequency-response ripple with adjustable algorithm
  • Measuring the coefficient of the total harmonic distortion (THD) of a signal
  • Saving and exporting data of spectral analysis
  • Measuring average level of sound pressure in time with adjustable algorithm (Bassrace, Bass Boxing, AMT SPL-Show, etc)
  • Changing the average weighted spectrum value on frequency and time (SQL)
  • Calculating amplitude spectrum average value
  • Supports work with two displays
  • Creating own Measuring modes (contest Ligues and Classes)
Measuring Center for Android and iOS
  • Simple interface
  • Build-in mic support
  • Unique algorithms
  • Supports Bluetooth and USB OTG and WiFi
  • Compatible with Android and iOS
Measuring Center for AndroidWireless Bass Meter(Second Edition)
Description
In modern world tablet PCs or smartphones are playing greater role in our lives. Devices, comparable in power with personal computers, gained a big part of the consumer market, supplanting PCs. For general consumer mobile devices completely replaced the functionality of PC, but specific tasks are still mostly solved using computers. It mostly happens because of the lack of necessary software. Our company goes with the times and offers its customers the possibility of using mobile devices for sound measuring and analysing. We have developed an application for spectral analysis of sound for Android. The application Measuring Center for Android is simplified version of the program for PC, but it still has its reach functionality. The interface of the program is intuitive and easy to use. It supports both the wired Spl-Lab devices (USB BASS Meter, USB RTA Meter, etc.) and wireless devices, such as Wireless Bass Meter. Also you can make measurements using build-it microphone of your phone or tablet!
Functions
  • Build-it mic support for AFC measurements (full version)
  • Measuring the amplitude-frequency characteristic (AFC) of a signal - displaying the spectrum
  • Measuring the Total harmonic distortion (THD)
  • Measuring the sound pressure level (SPL, dB Drag, IdBL, ESPL, AMT, etc)
  • Measuring average level of sound pressure in time (Bassrace, Bass Boxing, AMT SPL-Show, etc)
  • Measuring the average in time and whole spectrum sound pressure level (SQL)
  • Supports the wired and wireless Spl-Lab devices
  • Who's Online   0 Members, 0 Anonymous, 3159 Guests (See full list)
