Hi,
i am new to the channel, and probably this has been posted already, but I am doing a audio installation on a Mercedes 190 from 1993, and in this car the trunk is separated by a metal plate that goes from side to side. Behind this metal plate on the trunk is located the gas tank. My question is should I fully cover the metal plate with sound deadening material or just 2 or 3 bits.
also is there any tips on how I can improve the sub performance on this car (I am using a P2D4-10 on a ported box) ?
many thanks
Fil
HU - Alpine - CDA-9887R
Changer - Alpine - CHA-S624
Amp - RF - R600x5
Front Speakers - RF - P165-SI + Alpine SPG-10C2
Rear Speakers - RF - P1650
Sub - RF - P2D4-10 on Vented Box
Deaden everything you can. It makes a hell of a difference. Also for sub performance, try different box positions, its free and sometimes can gain some db's.
Alpine cde143bt/ Alpine ktp445u (4x45 amp)
2 Crescendo STS 1 (on alpine 4x45 on 2 channel mode)
4 Crescendo pwx 6.5's in front doors (Skar RP150.4)
1 Sundown zv3 12, SAE1500D.
Box is 2.5 cubes tuned to 30hz.
  • 3 weeks later...
Hi Kraken,
I’ve deaden the rear Deck and the back of the seats. On the rear deck i’ve Also removed the med kit tray and made a custom grills. Will post some pictures with in some days.
On the sub part i’ve Moved from a P1S4-10 to a P2D4-10 with coils in Parallel.
The sub now improved exponentially ?
many thanks
Movepage
Amp - RF - R600x5
Sweet. You can also try opening the front windows, rear windows, different doors open to see what sounds the loudest. On my truck, both windows being open is the loudest. if your box has room, try turning it different ways, like the sub facing up, facing the rear, facing front. Different box positions can sometimes gain sound
