dimondntr2004 Posted June 7, 2018 Report Posted June 7, 2018 i have 2 5000.1 d spl version amps need advice to keep 14 volts. I already have a singer 320 and limitless lithium 80 ah. Any suggestions will be appreciated
Crazy 8s Drums Posted June 7, 2018 Report Posted June 7, 2018 The XTR2500.1 pulls about 390 amps to achieve it's CEA RMS wattage of 2770 at 1 ohm. You have basically four times that potential....close to 1600 amps that could be used at max volume. Your 320a alternator alone is not enough to handle that and you don't have enough battery to store enough potential. Here is a BigDWiz vid for comparison purposes... Orion XTR amplifiers Skar subs
Crazy 8s Drums Posted June 7, 2018 Report Posted June 7, 2018 Your electrical cabling may not be enough either, but you didnt state what you have so we can't know... Orion XTR amplifiers Skar subs
dimondntr2004 Posted June 7, 2018 Author Report Posted June 7, 2018 was asking to see what else is needed to power them both. I have the 320 alt and lithium 80ah. wires are 2 gauge welding wire 3 + and - front to back .front battery is northstar group 31
Crazy 8s Drums Posted June 7, 2018 Report Posted June 7, 2018 2/0 gauge or just 2 gauge? Orion XTR amplifiers Skar subs
Crazy 8s Drums Posted June 7, 2018 Report Posted June 7, 2018 2 gauge is not going to cut it for what you are trying to do. Orion XTR amplifiers Skar subs
dimondntr2004 Posted June 7, 2018 Author Report Posted June 7, 2018 so 3 runs of 2 gauge to positive and negative is not enuff? what do you suggest to get it right. thanks for your input
Crazy 8s Drums Posted June 7, 2018 Report Posted June 7, 2018 At max output of your amplifiers, you'll need about 1600 amps of fusing just for the two Orion 5ks. I included a link in my last post to a chart that speaks of the capabilities of different gauge wire. There is also a lot more to this than simply running cables to amps and grounding them. As we don't know how you have it set up now we can't suggest what you need to do to get your gear operating at its fullest potential. You might take pics of your wiring and other install bits, maybe create a thread in the 'members build' section of the site. Folks could then see what you have and make suggestions... Orion XTR amplifiers Skar subs
Crazy 8s Drums Posted June 7, 2018 Report Posted June 7, 2018 Members builds... https://www.stevemeadedesigns.com/board/forum/13-member-rides-builds-show-off-your-whip-show-off-your-system/ Orion XTR amplifiers Skar subs
