i have dropped my jimmy 3" in the back and 2" in the front. the left side is almost 1" 1/2 lower than the right side both front and back is like this. i used drop blocks in the back and just took out the torsion key bolts out to drop it 2" in the front. what could be causing this anyone can help thanks
you got 2"s in the front?!!!!!!!!!! I did the same but i got maybe 1" in the front. The front you will have to adj. the bolts till its even. The rear i couldnt tell you, maybe check the blocks and see if they are the same. Might no have the blocks in right
1997 2 Door Blazer
Bagged & Body Dropped
SBC/TH350
I know that on the 2wd s10s and Blazers, theres this thing called the "Chevy Lean", almost all of them lean to the drivers side, it varies on the amount that it leans though. On your 4wd, idk, maybe you didnt get back together right
1997 S10 EC
Whats in it
106.9 Sq.ft. Hushmat
DB Elec. 250 amp alt.
HC800&HC1400
MLA Module
Alpine 9886
Knukonceptz wires
Clarion EQS746
poopy Alpine door co-ax's
Change IS Coming
So you removed the key? or did the flip? or took the adjuster bolts all the way out?
1997 2 Door Blazer
SBC/TH350
My s-10 definitely has the lean, though mine is a first gen.
Not sure if that carries through to the newer models like lil italy's
Team B2, Team Audiotechnix, Team Kicker, Team XS Power, Team Sundown, Team Maxxsonics, Team DD2008 Bassrace 130-139.9 Regional and National Champion2006, 2007, 2009, 2010 and 2012 MECA Champion (S1, SR1, S2, S3, S4, DB1) -1 DD 9510F + 2 Sundown SAZ2500's @ .7 ohm strapped=154.2 headrest, 129.2 driveby-2 DD 9510F's + 2 Sundown SAZ2500's @ 1 ohm strapped=154.0 headrest-1 DD 9512F + 2 Sundown SAZ2500's @ 1 ohm strapped=153.5 headrest, 131.1 Driveby
-2 DD 9512F + 2 B2 Zero1's @ .5 strapped= 157.0 headrest, 158.0 outlaw-1 Sundown SA-8 + 2 MB Quart 2000's=148.8 headrest, 150.6 outlaw
My buddys 01 Dime leans horribly, its almost a inch and a half
1997 S10 EC
Whats in it
HC800&HC1400
MLA Module
Alpine 9886
Knukonceptz wires
Clarion EQS746
Change IS Coming
Ive done 3" blocks in the rear and screwed out the torsion adj. bolts. I got about a 4" drop in the rear and maybe 1" maybe 1.5. I dont have a lean but i have just a bit of uneven front to back. Also got alot of squeaks but no suspension problems (knock on wood).
1997 2 Door Blazer
SBC/TH350
i had the squeaks but it only lasted bout 15mins then it went all away. ok so its just natual for the truck to lean is what it sounds like. kinda sux but i guess i can live with it thanks tom and anyone else that has anymore input
I think part of it has to do with the gas tank being only on the driver's side as well. 10+ gallons of gas isn't light. I think it makes it lean from the weight of the fuel and then it just kind of wears the suspension down over time.
  • Who's Online   0 Members, 0 Anonymous, 1665 Guests (See full list)
