ramman606 Posted July 11, 2018 Report Posted July 11, 2018 I have 4 sundown e8v5's I have built 2 boxes one slotted and one ported the slotted one sounds bests they are around .75 per sub tuned to 32 hz would more air space do better or not
Triticum Agricolam Posted July 12, 2018 Report Posted July 12, 2018 Making a ported box larger gets you more output, but only right around the tuning frequency. That may or may not be what you want. How much port area did you have on both your boxes? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
ramman606 Posted July 12, 2018 Author Report Posted July 12, 2018 its 3x10'' and 24'' long on the slotted box and 4''x8 on the round port
ramman606 Posted July 12, 2018 Author Report Posted July 12, 2018 ps. that some nice work ur doing on the sub boxes
Triticum Agricolam Posted July 13, 2018 Report Posted July 13, 2018 6 hours ago, ramman606 said: ps. that some nice work ur doing on the sub boxes Thanks! I'm glad you like my work! As far as your boxes go, I would certainly expect the slot ported box to outperform the aero port box. A single 4" port is very undersized for four E8 subs. Sundown recommends 8-12 sq of port area per sub, so that would take 3-4 4" ports. The 30 sq in of port area you had with your slot ported box is a lot better, but you would still most likely benefit significantly from even more port area. Its going to depend on how much power you are running. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
ramman606 Posted July 13, 2018 Author Report Posted July 13, 2018 so the round ported box I have needs 3- 4'' ports 4'' long right. and when building a slotted box say if its a box 12x12x12 and ur going to do a slotted port does the port area take any away from the box area
Triticum Agricolam Posted July 14, 2018 Report Posted July 14, 2018 5 hours ago, ramman606 said: so the round ported box I have needs 3- 4'' ports 4'' long right. and when building a slotted box say if its a box 12x12x12 and ur going to do a slotted port does the port area take any away from the box area No, I was suggesting you would need three or four 4" ports, they would need to be MUCH longer than 4" long to get the tuning you want. If you want to try an aeroport again you are better off using one or two large port vs 3+ smaller ones. A single 8" port would be great, but it will have to be 30" long or so. Depends on what the net volume of the box is. When calculating a box size the space the port takes up is taken away from the box volume. Net volume, which is what is left after you take into account the space the port/s, sub/s and bracing takes up is the volume number that's important. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
ramman606 Posted July 14, 2018 Author Report Posted July 14, 2018 the subs are in a 1993 mustang gt I've been working for 4 yrs
