Have a ported box for four 12’s was built under spec subs need 1.75 min and what I have is 1.48 after displacement. Would polyfil help? Plug the ports and just run sealed or just run 3 subs ? I was leaning on just running 3 as each set of two is on an amp at 2ohm for 1000 Watts I can have the single sub still at equal power as the others and gain airspace idk. Any suggestions would help Obviously a new box is got to happen when I can make that happen will take time.
What subs are they?   How much port area?
Polyfil won't help you, in ported boxes it only reduces output.
Assuming everything else is fine, there isn't going to be a huge difference in output between 1.48 cu ft net and 1.75 cu ft net.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 1609 Guests (See full list)
