Free WireTape with every Spectrum purchase
 Now through July 23rd, 2018 Only
37419712_2296348940376086_70168534277160
Always wonder how the pros get their Spectrum lines so clean and straight?  Here is your chance to get the tool to get that job done right. With this awesome deal, you get a free roll of Second Skin WireTape with any Spectrum order. When you lay this double sided wire tape down on the line you want the liquid sound deadening to stop, it will be ready to give you that clean and straight finish for all your projects. Once you are done spraying, you just find the end of the wire tape and pull it straight up while it cuts through the thick liquid Spectrum that has been applied. And if you add on our PlastiWrap with pre-taped double sided sticky tape, your project will clean up as easy as it goes on. Check out this video with Spectrum, WireTape, and PlastiWrap being used.
 Use Coupon Code: WIRETAPE
WWW.SECONDSKINAUDIO.COM
Edited by Second Skin
Now through July 23rd, 2018 Only Use Coupon Code: WIRETAPE
37579755_2298017336875913_69679092946708
Spectrum liquid sound deadening is not just for undercarriages, wheel wells, and interior metal......it works amazing for sub boxes, carts, generator box walls, and many more uses!!!
37412518_2297955086882138_87762658468518
