kindofanoob Posted August 16, 2018 Report Posted August 16, 2018 I have 2 skar ddx wired at 1 ohm to my apmi 2000. Both subs are working but only when 1 rca is plugged in. It doesn't matter which one is plugged in but if I plug both in the signal cuts off. Both subwoofers are working off the one rca. Just trying to troubleshoot or see if this is a problem. Thanks.
AlpineNut Posted August 16, 2018 Report Posted August 16, 2018 If you are going to bridge the amp the Left one is usually the one you want to have plugged in. Or if the amp is already Mono then the left one. 73456w9vbwevsdb sodtbsorutnvsd sdtuspdun sd d f gsdfiusd gdf n
